what should be the voptium value of L/G for flow in a wet induced draught cooling tower?i ve heard it should lie between 1 and 1.1.is it true?please clarify.
L/g Value In A Cooling Tower
Started by shiny, Mar 08 2008 06:01 AM
Posted 08 March 2008 - 06:01 AM
Posted 11 March 2008 - 02:48 PM
QUOTE (shiny @ Mar 8 2008, 04:01 PM) <{POST_SNAPBACK}>
L/G ratio in cooling tower design effects the tower in tow ways .i-e. Height of tower and fan power
If we increase the L/G ratio the fan power required will increase and height of tower decrase and vise versa for decrease in L/G ratio. Now you have to optimaize between operating cost and installation cost ..
for quick estimate of L/G ratio ..... Look Perry's hand book of chemical engineering there .. Optimum heights of coolinh towers are given for several ranges and approches select such a L/G ratio that your height of cooling tower falls in between the optimum limista disscused in perry... hope this helps you out
Absorption TowerStarted by Guest_mixednuts_* , 09 May 2013 |
Distillation Tower With Two ReboilersStarted by Guest_trungphu_* , 19 Apr 2013 |
Tower Overfilling With Heat Input CalsStarted by Guest_bdanave_* , 25 Apr 2013 |
Atmospheric Tower Stripping Steam Vs Crude RateStarted by Guest_ken0564_* , 30 Jan 2013 |
Amine Absorption TowerStarted by Guest_m.r.rahimzadeh_* , 31 Mar 2013 |
