Hi !
I would like to know that if we need to fill Propylene into LPG tanks (or Vice versa )..what are the things that needs to be carried out for adequacy checks.Design of the vessel will be for a Particular design pressure and Temp.
also if we need to change PSV on vessel (Propylene will exert higher vapor pressure at same temparature).
I dont think that density change will make any difference because spheres/Bullets are already designed for bearing water(Hydrotesting ).
Please Elaborate and please add what you feel is related to above mentioned subject.
Lpg And Propylene Storage Tanks
Started by Himanshu Sharma, Apr 28 2008 03:39 AM
Posted 28 April 2008 - 03:39 AM
Posted 28 April 2008 - 06:24 AM
If you are proposing to convert LPG vessels into Propylene use, why don't you tell the readers what the original process conditions are and what the PROPOSED CONDITIONS are also - so that we all don't have to do the meticulous searching of the properties through the Thermo database. You surely have already done this work; so, why don't you share your data with us? It is the least thing you could do when you are asking for assistance.
Await your reply.
Await your reply.
Sulphuric Acid H2So4 Storage TankStarted by Guest_TeeEng_* , 08 Apr 2024 |
Butadiene StorageStarted by Guest_Mirzazada_* , 27 Mar 2021 |
Green Diesel StorageStarted by Guest_Lucianaa_* , 16 Feb 2024 |
Determination Of The Number Of Foam Chambers For Storage TanksStarted by Guest_AnbIran_* , 15 Feb 2024 |
Crude Oil Storage CapacityStarted by Guest_Noman97_* , 19 Jan 2024 |
