I am looking to design a packed distillation column and the information is very limited. I'm looking to get a general idea of a column's height and diameter to fit a separation of Methanol and Water. The column is going to be bought from a surplus store and is not exactly known what media will be in the column or what size. I have already done some calculations and came up with 10 ideal stages for this process. It is going to be a relatively small column. Are there any generic ratios for height to diameter that anyone knows of? I know they don't normally teach you that type of thing in school but if someone has many years of experience they might be able to give me a better idea. Here is the information I know right now.
Separation of 90% Methanol and Water solution.
Methanol off the top is 98% pure
10 ideal stages
HETP is normally somewhere between 1 - 3 m
Flow is very small
Thank you.
Distillation Column
Started by acbaker, Apr 29 2008 07:44 AM
Posted 29 April 2008 - 07:44 AM
Posted 29 April 2008 - 08:20 AM
It is going to be very difficult to develop a solution without the mass flow. Further I strongly suggest that you get the media uncertainty sorted as hETP values of 1-3 with produce widely different designs.
A few questions though.
Why a packed column, student experiemnts?
Have you calculated actual stages?
Surely when calculating the ideal stages you could easily work out the diameter?
Finally I do not know what school you are in but this is a problem that you should be able to sort as a third year in Chem Eng. Distillation is bread and butter for us. So if you are not in chem Eng, you may contact your local group/uni?
Reactive Distillation MtbeStarted by Guest_Michael Mitra_* , 15 Mar 2024 |
Vacuum DistillationStarted by Guest_hysyshunter_* , 12 Mar 2024 |
Distillation Column DiameterStarted by Guest_refluxraider_* , 12 Mar 2024 |
DistillationStarted by Guest_refluxraider_* , 13 Mar 2024 |
Diameters Of A Structured Packing Distillation Column With No VapourStarted by Guest_hysyshunter_* , 07 Mar 2024 |
