Dear Art,
I was going through the crane fluid flow problems which you compiled in excel format. Its a great thing to know about hydraulics. the only problem i faced was that is in British/ American unit . As I am educated in metric unit it sometimes gives problem. Is their any metric equivalent of it ?
Crane Fluid Flow Problem
Started by ayan_dg, Jun 16 2008 05:56 AM
Posted 16 June 2008 - 05:56 AM
Posted 16 June 2008 - 07:42 AM
Ayan:
No, there is no IS (International System) version of my Crane Problems workbook. You should be able to easily convert the USA Customary units to IS units. An excellent units conversion program like "Uconeer" is available for free on the Internet and is made for this purpose.
Posted 17 June 2008 - 01:00 AM
QUOTE (ayan_dg @ Jun 16 2008, 05:56 AM) <{POST_SNAPBACK}>
Dear Art,
Ayan,
Conversion between unit is one of the characteristic stop engineer to progress. Don't left this skill... You will meet many conversion problem in real engineering world !!!
Posted 17 June 2008 - 05:32 PM
QUOTE (JoeWong @ Jun 16 2008, 10:00 PM) <{POST_SNAPBACK}>
Very important point. Conversion of units should be NO PROBLEM for any engineer. You must master this aspect of typical engineering calculations - you'll see it often.
Flow Switch High RangeStarted by Guest_Lyne_* , 11 Apr 2024 |
Kettle Reboiler Flow FractionsStarted by Guest_Lyne_* , 31 Mar 2024 |
Mtbe Process Flow Diagram Master Thesis.Started by Guest_sayoub_* , 15 Feb 2024 |
Time Required To Heat Up A Fluid In A VesselStarted by Guest_panagiotis_* , 24 Jan 2023 |
Duplication Of Psv And Flow Rate For Exchanger Tube Rupture ScenarioStarted by Guest_Platonicus_* , 11 Mar 2024 |
