how to apply heat balance in a shell and tube heat exchanger if tube side fluid is undergoing chemical reactions and as well as temp. change? for example, in my case inlet tube side fluid is alcohol and acid while outlet is ester at diff temp?
Heat Exchanger
Started by saurav, Jun 22 2008 11:27 PM
Posted 22 June 2008 - 11:27 PM
Posted 23 June 2008 - 11:14 PM
QUOTE (saurav @ Jun 23 2008, 11:27 AM) <{POST_SNAPBACK}>
firstly, we have to consider the hydraulic change in tube. looking that the ester provides more volume flow rate or not. this step will define the caracteristic of the tube of HX. In energy field, we calculate the reaction as the tube reactor (plug flow) to see the conversion of the reaction then we will know the heat of reaction (i don't sure that is it an endothermic one ?) Good luck
Time Required To Heat Up A Fluid In A VesselStarted by Guest_panagiotis_* , 24 Jan 2023 |
Plate Fin Heat ExchangerStarted by Guest_shazzad1613_* , 23 Mar 2024 |
Duplication Of Psv And Flow Rate For Exchanger Tube Rupture ScenarioStarted by Guest_Platonicus_* , 11 Mar 2024 |
