I have a glass tube HX with sulfuric acid on the tube side and cooling water on the shell side. I know the input and output temperatures of both. I know the flow (gpm) of each. The HX is a counter current design. I also know the lenght of the HX, # of tubes and thickness of tubes. What is the calculation to find the "hottest" temperature the cooling tower water will contact or be? I want to prevent the precipitation of hardness onto the tubes.
Also, will this calculation also be used for a steam condensor? If not what changes needed to be made.
Hx Glass Tube
Started by waterguy, Jul 09 2008 05:59 AM
No replies to this topic
Posted 09 July 2008 - 05:59 AM
Duplication Of Psv And Flow Rate For Exchanger Tube Rupture ScenarioStarted by Guest_Platonicus_* , 11 Mar 2024 |
Aspen Edr, Shell And Tube, Velocity In TubesStarted by Guest_Mehdi534_* , 09 Jan 2024 |
Current Operating Pressure 95 Psig In Shell Side Of Shell-Tube He AndStarted by Guest_Hafiz_Che_* , 09 Dec 2023 |
Floating Head Rule For Shell And Tube ExchangerStarted by Guest_Ghasem.Bashiri_* , 06 Dec 2023 |
Hx Psv Sizing: Tube Side Fire Case With Shell Side Being Steam.Started by Guest_tamueng_* , 07 Nov 2023 |
