To maintain minimum recirculation flow through BFP during all operational conditions arrangement of recirculation line with orifice from pump discharge to deareator is being chosen.
The inputs are from pump curve the max pressure at req minimum flow of 525m3/hr is 75kg/cm2 & deareator pressure is 5kg/cm2 please elaborate the broad steps i should follow for sizing of orifice & line.
regards
Recirculation Line Sizing In Bfp For Minimum Flow
Started by rsk, Jul 16 2008 07:46 AM
No replies to this topic
Posted 16 July 2008 - 07:46 AM
Flow Switch High RangeStarted by Guest_Lyne_* , 11 Apr 2024 |
Pump Sizing ConsiderationsStarted by Guest_panagiotis_* , 07 Apr 2024 |
Barometric Legs Line SizingStarted by Guest_panagiotis_* , 17 Mar 2023 |
Kettle Reboiler Flow FractionsStarted by Guest_Lyne_* , 31 Mar 2024 |
Mtbe Process Flow Diagram Master Thesis.Started by Guest_sayoub_* , 15 Feb 2024 |
