condensate water make up system,
Condensate water storage tank(located at 100m elevn reference & normal water level 108m) of 300 m3 open to atmosphere is feeding hotwell at 107m elevn through hotwell make up pumps (centre line 100.2m) & make up CVs.
Frictional losses at operating flow
suction pipe=0.1mwc
discharge pipe=25mwc
other losses=5 mwc
1.In design of these systems what is the minimum level to be maintained in CST to prevent vortexing & loss in condenser vacuume.
2. what are the design inherent features given to prevent loss of vacuume in condenser in case of nontripping of pumps on very low level.
Sorry i could not attach the excel sheet, as it was showing error.
regards
Condensate Make Up System
Started by rsk, Jul 16 2008 12:27 PM
Handling The Limited Capacity Of Flare SystemStarted by Guest__1angelia23_* , 05 Apr 2024 |
Closed Drain SystemStarted by Guest_Falah_* , 26 Mar 2024 |
Lube Oil System For TurbomachineryStarted by Guest_bckesim_* , 03 Mar 2024 |
Design Criteria For Sizing Sump Drum Of Close Drain System In Tank FarStarted by Guest_AnbIran_* , 28 Feb 2024 |
High Pressure Condensate Recovery To Low Pressure DeaeratorStarted by Guest_hd_1982_* , 16 Feb 2024 |
