for sizing of Control valve differential pressure across it is taken to be 25-30% of overall diff pressure
why not 100% it will give linear response . Please enlighten on this.
regards
Control Valve Sizing
Started by rsk, Jul 17 2008 11:02 AM
Posted 17 July 2008 - 11:02 AM
Posted 18 July 2008 - 04:38 AM
QUOTE (rsk @ Jul 17 2008, 12:02 PM) <{POST_SNAPBACK}>
regards
regards
25-33% sort of rule of thumb and believe to provide correct control capabilty for maximum and turndwn condition. This has to be confirmed during Detailed Design.
100% would be too much. For example, a pump with long pipeline (pressure drop =~50 bar). If you provide 100% pressure drop on control valve (50 bar), the pump shall provide extra 50 bar and letdown through the control valve. It waste a lot of energy. Apart large pressure drop may cause cavitation and nosie problem. Anti-cavitation trim may required. It increase cost. The only good thing is, you may have smaller control valve. for long run, the life cycle cost may prefer low DP Control valve option.
Posted 18 July 2008 - 08:22 AM
The way I look at this situation is that if my control valve is either 0% or 100% open, I am out-of-control. I only have control when my controller can take effective action. It cannot do so when fully open or closed. Also, since my ability to calculate future conditions is less than perfect, I like to further limit the range my valve will operate to 15% to 85% - and that's only because I consider myself to be a very good estimator ;-).
Answered
Vacuum Ejector Pressure ControlStarted by Guest_himanshu.ch_* , 19 Mar 2024 |
Sizing Of Vertical/horizontal Flash DrumStarted by Guest_Mohammad3799_* , 10 Mar 2024 |
Design Criteria For Sizing Sump Drum Of Close Drain System In Tank FarStarted by Guest_AnbIran_* , 28 Feb 2024 |
Ro SizingStarted by Guest_T_bag_* , 27 Feb 2024 |
Vent Sizing Using GooseneckStarted by Guest_mychemicalromance0425_* , 23 Feb 2024 |
