Reactors In Series
Started by alovera88, Jul 29 2008 02:36 AM
9 replies to this topic
Posted 29 July 2008 - 02:36 AM
Hi everyone, I've got a problem where I have a two CSTR's joined together by a pipe that can be considered to be a PFR. I know the volumes of the reactors, the rate constant and the overall conversion, but I'm just stumped how I place all the design equations together (to make an implicit equation) to find out the volumetric flow rate for the desired conversion.
Any hints would be greatly appreciated, as I feel I am almost there.
Thanks.
Alex
(p.s. it is a liquid phase, first order reaction of species A to B.
90% conversion from A to B and there is no B in the feedstock)
Thanks.
Alex
Posted 29 July 2008 - 04:11 PM
solve equations:
1) Q*cA0=k*cA1*V1+Q*cA1
2) cA2=cA1*exp[-k*(V2/Q)]
3) Q*cA2=k*cA3*V3+Q*cA3
4) (cA0-cA3)/cA0=0.9
4 equations and for unknown variables: cA1,cA2,cA3,Q - solve for Q
Q - volumetric flow
cAi - concentrations: 0-inlet, 1-after 1st CSTR, 2-after PFR, 3-outlet (after 2nd CSTR)
Vi - volumes of reactors
k - reaction rate constant
Q - volumetric flow
Posted 04 August 2008 - 09:53 AM
QUOTE (Andree @ Jul 29 2008, 09:11 PM) <{POST_SNAPBACK}>
solve equations:
Q - volumetric flow
Q - volumetric flow
Hi, thanks for your reply, will have a look at it when I'm back from a trip.
Much appreciated , Alex
Posted 06 August 2008 - 04:33 AM
Hey Andree,
jus been trying to work through the equations, but keep getting stuck, maybe my algebra's just rusty.
(1) Q*cA0=k*cA1*V1+Q*cA1
(2) cA2=cA1*exp[-k*(V2/Q)]
(3) Q*cA2=k*cA3*V3+Q*cA3
(4) (cA0-cA3)/cA0=0.9
[Values: V1,V3 = 5m^3
V2 = 11m^3
k = 0.1s^-1 ]
Starting from (4) we know that: cA3 = 0.1 , we can then complete the other equtions:
(1*) Q = (0.5*cA1) / ( 1 - cA1) [or] (1**) cA1 = Q / (0.5 + Q)
(3*) Q = 0.05 / (cA2 - 0.1) [or] (3**) cA2 = (0.05 / Q) + 0.1
Now we put these into equation (2) (1** and 3**) and taking logs to remove the exponent, but i can't seem to get my head around the next bit. Sorry if this seems trivial to you, but it's starting to annoy me as i know it should be relatively easy, but I can't see the solution!
Thanks again for your time.
V2 = 11m^3
k = 0.1s^-1 ]
Posted 06 August 2008 - 04:59 AM
QUOTE (alovera88 @ Aug 6 2008, 10:33 AM) <{POST_SNAPBACK}>
cA3/cA0 = 0.1
Posted 06 August 2008 - 05:08 AM
I suggest solving the system of eqns numerically - analytically can be difficult (maybe even impossible) as you will have "Q" in exponent... I recommend MathCAD, which is very convenient for this purpose.
Posted 08 August 2008 - 04:43 AM
approx. 0.9593 [m3/s] - it seems to be too much (not realistic value unless it is a student task)
Posted 08 August 2008 - 07:48 AM
QUOTE (Andree @ Aug 8 2008, 10:43 AM) <{POST_SNAPBACK}>
Yeah, it's a student question, but should be able to be answered using just the design equations and I'm sure there must be a simpler way
thanks for the answer though, atleast it gives me something to work towards
Alex
Posted 08 August 2008 - 08:45 AM
to avoid wrtiting a numerical code (if you have no access to any math software, i.e. Mathcad or Matlab), you can find solution using simple spreadsheet... put guess value of Q and check if l.h.s of final equation is equal to r.h.s. ;-)
Posted 09 August 2008 - 03:05 AM
Excel can be used for iterative calculation.
1. We can simplify Andree's 4 equ's to become 2 equ's, like
Q1=f(Q2)
Q2=f(Q1)
2. Type the two equ's into Excel's two cells.
(Note that Q1 cell and Q2 cell need each other)
3. check the menu command/...Options/Tools/Calculation tab/Iteration checkbox,
select the iterative number(default=100).
It is vary easy, you could try it yourself.
Q1=f(Q2)
Q2=f(Q1)
Using Similar Check Valve In SeriesStarted by Guest_vsnlbom_* , 22 Dec 2023 |
Aspen Edr - S&t: Process Side Series / Cw Side ParallelStarted by Guest_mitch22_* , 06 Feb 2023 |
Switching From Parallel Mode Into Series ModeStarted by Guest_ahmed abd elmonem_* , 17 Jan 2023 |
Npsha For Series PumpStarted by Guest_Farahin_* , 05 Sep 2022 |
Selectivity In Series ReactionsStarted by Guest_kjwx109_* , 03 Sep 2022 |
