Hi
I am looking for good practical books to invest on.
The two areas are:
1. Control Valves and
2. Safety Relief Valves
I would appreciate any suggestion on these topics.
waa15
Control Valves And Safety Relief Valves
Started by Bayo Alabi, Aug 11 2008 06:34 AM
Posted 11 August 2008 - 06:34 AM
Posted 11 August 2008 - 10:12 AM
WAA15:
I don't believe that the conventional text books are effective in giving you the detailed and specific information on what you are looking for.
For Control Valves, you don't need to spend any money. You can download the Classic book on CV from Fisher Controls (Emerson) at: http://www.emersonprocess.com/fisher/products/documentation.html
And for information on Pressure Relief Valves, you should obtain and study 3 basic documents:
1) API 520 part I;
2) API 520 part II; &
3) API 521
Even if you go ahead and invest in conventional text books (which is even better), you will still need to have what I have outlined above. So, I would go and directly obtain the Fisher Information for Free and invest in the API documentation. All this information is readily available through the Internet.
1) API 520 part I;
3) API 521
Hydrocarbon Dew Point Control UnitStarted by Guest_BabRafiq1_* , 05 Apr 2024 |
Pressure Control Valve Issues For Gsw LinesStarted by Guest_fahadazh_* , 29 Mar 2024 |
Answered
Vacuum Ejector Pressure ControlStarted by Guest_himanshu.ch_* , 19 Mar 2024 |
Air Consumption For On Off ValvesStarted by Guest_itsmetinnie_* , 11 Mar 2024 |
