Hi all
I really need your help..
will explain to u what I am going to do exactly
1) I have to built a filter pilot plant for water treatment
For this filter, i have decided that to built the filter with three sections two PVC columns sections and one in the middle is Perspex column ( clear acrylic ) 300mm in outside diameter and 1m length.. but we prefere the thickness would be around 8mm
2) i can tell u that: i need to pump water from the bottom section of the filter which will be a PVC section,, and the flow rate will be around 180 L/H.to 300 L/H.. and the velocity will be around 5m/h and 10m/h..and i will put some materilas ( polymer beads ) inside the filter that will treat the water. i will pump air as well from the bottom to wash the materials once it is dirty..
By the way: my flow will be upflow
My qusestions are
1- What is the downflow wash water for floating media filter ? and what is upward wash air for floating media filter ? Is there any range ? in oder words : what is the typical backwash rate for upflow floating media filter ?
2- Could i calculate the amount of water and air the i need it for backwashing the media ? Could u help me with it ?
3- How can i calculate the pressure loss through the media before running any experiments ?
4-What about the required pressure of the system ?
I really have no feeling about these questions.. so could u help me with them ?
Best regards
Please Help Me With Pressure Drop
Started by Bashir, Aug 13 2008 10:27 AM
No replies to this topic
Posted 13 August 2008 - 10:27 AM
Answered
Steam Pressure Requirements For Limpet Batch ReactorStarted by Guest_golegolegole_* , 10 Apr 2024 |
Pressure Control Valve Issues For Gsw LinesStarted by Guest_fahadazh_* , 29 Mar 2024 |
Vapor PressureStarted by Guest_Hamza1111_* , 23 Mar 2024 |
Answered
Vacuum Ejector Pressure ControlStarted by Guest_himanshu.ch_* , 19 Mar 2024 |
