Hello everybody..
I have aquestion and hope to get help..please bear with me and try to finish reading my question..
Thank u very much for your time.
My question is
I have a pilot plant filter.. and i need to add some chemicals to the raw water before entering the filter..say for instance the water flow rate is around 20L/h
the concentration of the chmical solution is %10 by weight.. and i need to add (dose) 5mg/L...which means 5mg of the chemials to 1L of water (flows in pipe before the filter )..
My question is how much (liter or milliters ) of the solution (chemicals) should i dose it to the water to give me the 5mg/l ?
I need to solve this problem in order to get the specification of the right dosing pump that i need to buy..
So please try to help me out with this.
Thank u very much
Please Help Me With This Question
Started by Bashir, Aug 27 2008 09:18 AM
Posted 27 August 2008 - 09:18 AM
Posted 27 August 2008 - 09:37 AM
Bashir,
Calculate the net rate of pure chemical (mg/h), based on given water flow and required concentration of chemical. Since it is highly diluted system, you can neglect the presence of water in the chemical solution - this will give you the solution flowrate which is ten times higher that the pure chemical flow.
Pure chemical flow, mg/h = (Water volumetric flow) x (5 mg/L)
Chemical solution flow = 10 x (Pure chemical flow)
I hope this wasn't too difficult.
Posted 27 August 2008 - 09:38 AM
(very) approx. 0.1 l/h
Posted 27 August 2008 - 09:40 AM
QUOTE (Andree @ Aug 27 2008, 03:38 PM) <{POST_SNAPBACK}>
assuming that %10 means 0.1%
Posted 27 August 2008 - 02:11 PM
Hi friends
First of all thank for replying.. but i really confused.. i still do not understand it.
How can ignore the water in solution ( the stock solution is 10% concentration) and i need to dose 5mg/l of water flow through the system..So much exactly i need to dose from this solution to the raw water flow ? in other words how mls (mililiter per hr) ? Please try to expalin with some details..
Thank u very much
Thank u very much
Epc Basic QuestionStarted by Guest_poojabathula369@gmail.com_* , Yesterday, 03:15 PM |
Overpressure Scenario QuestionStarted by Guest_panagiotis_* , 08 Mar 2024 |
Falling Film Evaporator Basic QuestionStarted by Guest_panagiotis_* , 13 Mar 2023 |
Doubt In Mass Transfer QuestionStarted by Guest_guiromero_* , 11 May 2023 |
Question Distillation Column Transport PropertiesStarted by Guest_panagiotis_* , 05 Apr 2023 |
