In low pressure , medium & high pressure steam we should use reduced port or full port gate valve.
MOC is CS.
PME
Refinery
Started by PME, Sep 09 2008 10:14 PM
Posted 09 September 2008 - 10:14 PM
Posted 11 September 2008 - 10:52 AM
QUOTE (PME @ Sep 9 2008, 07:14 PM) <{POST_SNAPBACK}>
MOC is CS.
MOC is CS.
PME,
You should use a "normal" gate valve which, using this terminology, would be called a reduced port valve.
Literature To Read For Refinery Oil MovementStarted by Guest_Noman97_* , 09 Nov 2023 |
Refinery Amine Regeneration UnitStarted by Guest_CHEMSTRONG_* , 16 Jun 2022 |
Refinery DesalterStarted by Guest_CHEMSTRONG_* , 19 Apr 2022 |
Refinery Fccu QueryStarted by Guest_CHEMSTRONG_* , 07 Apr 2022 |
Refinery Corrosion InhibitorsStarted by Guest_CHEMSTRONG_* , 03 Apr 2022 |
