Dear,
I am working on "styrene monomer' plant for 8 years as plant engineer,
to recovery of valuable hydrocarbons from vent gas stream( after reaction section) we use scrubber/stripper columns, and we use "flux oil" ( heavier H.C than three ethyl benzene that produced in Ethyl benzene unit) as scrubbing media.
at srubber we absorb HC fron vent gas stream and resulted media is subjected to steam stripper to recovery of HC from Flux oil and Fux oil return to scrubber.
in last years we need to make up flux oil 1 time per week, but todays we have 3 time per day make up.
I am not shure that steam flow transmitter is shurely working correctly, but i will be thankfull if you said what parameters can cause this problem. also i will be thankfull if you give me a good refrence about steam distillation and steam stripping.
thanks
Vent Gas Stripper
Started by adeliry, Sep 12 2008 01:54 AM
No replies to this topic
Posted 12 September 2008 - 01:54 AM
Vent Sizing Using GooseneckStarted by Guest_mychemicalromance0425_* , 23 Feb 2024 |
Pressurized Deaerator Tank Exhaust Vent SizingStarted by Guest_zezima_* , 01 Feb 2024 |
Side Stripper Vs Separate ColumnStarted by Guest_waheed2020_* , 13 Jan 2024 |
Gas Seal In Hydrogen Vent StackStarted by Guest_Afshin445_* , 27 Dec 2023 |
Controlled Type Blowdown Through Vent Stack, Reach Mach 1Started by Guest_x127127@hotmail.com_* , 16 Dec 2017 |
