I am nowadays designing a shell and tube heat echanger and the problem I am facing is that I want estimates of film coefficients for some common gases like ammonia,carbon di oxide,etc in the pressure range of 0.1-10kPa.
Heat Transfer Coefficients
Started by Engineers Are The Best, Sep 14 2008 07:55 AM
Posted 14 September 2008 - 07:55 AM
Posted 14 September 2008 - 08:30 AM
Refer to any engineering textbook, such as Kern, Ludwig, GPSA etc. You have examples there. The ranges of U-values for your application should be somewhere in the range 5-40 W/m2C. Google this topic.
Check this link at ChE: U in heat exchangers
Posted 18 September 2008 - 11:01 AM
Thank you for giving me a small but good guide.
Posted 18 September 2008 - 11:25 AM
Remember that the actual film coefficient will be the result of exchanger design you have chosen. The point is to select such exchanger type/geometry which will give you satisfactory heat transfer coefficient - the one you were targeting - and by taking into account all specific issues in the system you are dealing with.
Look also at this article by V. Ganapathy: Get heat transfer coefficient - Pressure effect on crossflow
If you cannot reach the references I mentioned in my previous post, let me know.
Time Required To Heat Up A Fluid In A VesselStarted by Guest_panagiotis_* , 24 Jan 2023 |
Plate Fin Heat ExchangerStarted by Guest_shazzad1613_* , 23 Mar 2024 |
Heat Exchanger Temperature CrossStarted by Guest_kaidlut_* , 20 Dec 2022 |
