i have a problem in covnverging the high pressure stripper (in hysys case, i use absorber) so. the message appear when i try to run the column "fatal error - zero diagonal....'
so.. what should i do to converge it..
here is attached the work dat i've done.
and i'm using hysys v 3.2. (older version)
Problem In Simulation Using Hysys - Case Study: Urea Production
Started by hazmee, Sep 17 2008 12:50 PM
Posted 17 September 2008 - 12:50 PM
Posted 18 September 2008 - 07:54 AM
QUOTE (hazmee @ Sep 17 2008, 11:20 PM) <{POST_SNAPBACK}>
Dear,
Where is the attachment? And tell me us the detailed background of your simulation?
Posted 18 September 2008 - 10:05 AM
You usually get that message when the vapor or the liquid flow becomes zero on one or more trays. Check all your inputs, feed streams etc. and your specs first. See if you can use damping to avoid oscillations while converging. Try another solver method. Try different specs, if you can. Improve your initial estimates, especially the temperature profile.
If you tried all this, and still have problems, post your case here and we'll see if we can help you out.
Aspen Hysys - Creating A New Component And Defining PropertiesStarted by Guest_catiiiii_* , Yesterday, 11:42 AM |
Methanol ProductionStarted by Guest_Manue_* , 21 Mar 2024 |
How To Find K-Values Of A Hydrocarbon Mixture On Aspen Hysys?Started by Guest_Alexis Azamar_* , 08 Apr 2024 |
Ammonium Sulfate Process SimulationStarted by Guest_amir55261_* , 06 Apr 2024 |
Extension Reaction Kinetic In HysysStarted by Guest_Ulbert Zsolt_* , 29 Mar 2024 |
