Hi
I need to heat a 98% sucrose and water mixture and would like to calculate a heat value in kJ/kg. Is there any way to combine the two heat capacities into a relative heat capacity for the mixture?
thanks
Heat Capacity
Started by , Nov 03 2008 02:05 PM
Posted 03 November 2008 - 02:05 PM
Posted 04 November 2008 - 04:19 AM
I know this is not the real answer you need, but you might find something that helps you at
http://www.sugartech...acity/index.php
Posted 04 November 2008 - 06:15 AM
QUOTE (winchester @ Nov 4 2008, 12:05 AM) <{POST_SNAPBACK}>
Hi
thanks
thanks
Your query is not conceptually concieveable by me;
as Sucrose crystals do have water of hydration and total water contents of normal sucrose might be more than 2% I understand.
Kindly re-think/re-phrase.
qalander
Time Required To Heat Up A Fluid In A VesselStarted by Guest_panagiotis_* , 24 Jan 2023 |
Plate Fin Heat ExchangerStarted by Guest_shazzad1613_* , 23 Mar 2024 |
Heat Exchanger Temperature CrossStarted by Guest_kaidlut_* , 20 Dec 2022 |
Temperature Cross Heat ExchangerStarted by Guest_Priolo_* , 12 Aug 2019 |
Best Heat Exchanger Type For Gas HeatingStarted by Guest_golegolegole_* , 29 Jan 2024 |
