Has anyone a nice example of an Excel Sheet set-up to carry out iterative mass balance calculations involving recycle and purge? I would be interested in the ammonia synthesis loop example. Cheers
Material Balance Calculations With Recycle And Purge On Excel
Started by cosmochronos, Nov 21 2008 11:26 AM
Posted 21 November 2008 - 11:26 AM
Posted 21 November 2008 - 12:27 PM
Cosmo:
Isn't this a routine type of assignment that all Chemical Engineering Students should be doing in order to fully master and dominate the use of spreadsheets as calculating tools?
If you don't develop your own spreadsheets, how are you going to learn to do it? And if you claim that you can do it, why don't you?
Trust me. It is far more profitable for you, as a student, to develop your own spreadsheet programs than it is if you get it from others.
Mass Balance ErrorStarted by Guest_Mohammad3799_* , 19 Feb 2024 |
Iso 28300 Venting CalculationsStarted by Guest_Mikemak_* , 22 Feb 2024 |
Vapor Balance Line From Pump Cane VentsStarted by Guest_100RB_* , 03 Jan 2024 |
In & Out Breathing Flow CalculationsStarted by Guest_Ankit_Kumar_* , 28 Oct 2015 |
How To Switch 2 Aspen Hysys Simulations When Connected To ExcelStarted by Guest_nfbeusebio_* , 14 Nov 2023 |
