Hi!
Does anyone know a good way to estimate the viscosity of a mixture? I did a little research online and some papers mentioned the Grunberg Equation, but I couldn't find the actual equation.
Estimating Viscosities Of Mixtures
Started by allison, Nov 22 2008 09:16 PM
Posted 22 November 2008 - 09:16 PM
Posted 23 November 2008 - 11:16 AM
Allison,
If you had made an effort to use the search feature on the forum you would have found plenty of references. Here is one from the forum itself:
http://www.cheresour...ure viscosities
Posted 23 November 2008 - 11:36 AM
It depends on what do you need these viscosities for; sometimes, the weighted or volumetric average value is accurate enough.
For hydrocarbon mixtures, very good reference is "Petroleum refinery engineering" by W. Nelson.
UniSim software offers an interesting and quite accurate procedure for calculating viscosity of heavy crude/condensate blends (Shu's correlation). You will need specific gravity of each fraction contained in the mixture. The document is attached below.
Viscosity_of_Heavy_Oil_and_Condensate_Blends.pdf 131.62KB 43 downloads
Heat Required For Boiling Liquid MixturesStarted by Guest_halkeshhulk_* , 07 Oct 2023 |
Heat Requirement For Vaporizing Of Liquid MixturesStarted by Guest_Venkat @89_* , 24 Feb 2023 |
Liquid Mixtures Properties EvaluationStarted by Guest_Jorge Kley_* , 21 Dec 2022 |
Impellers For Solid-Liquid MixturesStarted by Guest_kangas_* , 08 Sep 2020 |
Answered
Critical Properties Of Gas MixturesStarted by Guest_Guilhermexift_* , 09 Jun 2019 |
