yeah, I'll clarify. E.G., Plant air will contains some particles that are not filtered, so by this way may be will effect on the equipment after long time.
did you get what i want >>?
No, betty, we did NOT get what is needed to supply you with a meaningful answer. That is what Mr. Montemayor has tried to tell you. You have a knowledgable, helpful audience "out there" that would be happy to assist you. BUT, you must assist us by formulating direct, succinct, meaningful questions that clearly indicate your needs and adequately supply all that the reader needs to develop a response. When you don't get a response, then either no one knows the answer (which is unlikely IF you have correctly identified your topic), or you have failed to meet the criteria stated above.
With your most general inquiry, all you can expect is a very general response. So, what are the hazards? Well, you might have high temperatures, high pressures, substances that could exclude oxygen, etc. That's about all I can say given the information you have provided.
Also, it is normally understood that hazardous = dangerous to humans. The above statement suggests that you are asking about possible erosive behavior to equipment. What is it?
