Hi
I'm working on a project in which I have to model flue gas acid dew point for a coal plant. I am using Verhoff's sulfuric acid dew point calculation method but I got the idea that the method is not accurate for high temperatures. I'll like to know what the temperature range for which verhoff's method is validated (accurate) and any suggestions on the method to use outside this range. Thanks a lot.
nwike
Valid Temperature Range For Verhoff's Sulfuric Acid Dew Point Calc
Started by nwike, Jun 01 2009 08:20 AM
Caloric Temperature CalculationStarted by Guest_bckesim_* , 10 Apr 2024 |
Flow Switch High RangeStarted by Guest_Lyne_* , 11 Apr 2024 |
Sulphuric Acid H2So4 Storage TankStarted by Guest_TeeEng_* , 08 Apr 2024 |
Hydrocarbon Dew Point Control UnitStarted by Guest_BabRafiq1_* , 05 Apr 2024 |
Sulfuric Acid PlantStarted by Guest_Kartik54_* , 16 Mar 2024 |
