We're currently studying the rankine regenerative cycle this semister. I have two main questions here:
1. Can you have and open feed water mixer with out using two pumps? (I've googled this and it doesn't show any rankine cycles without the use of two pumps. The problem is that our Dr. suggested that you can let the portion of steam leaving the turbine mix directly in the heater with the liquid leaving the condensor. And that the pressure of the resulting steam is the net average of the pressure of both steams: P3=(P1+P2)/2), this brings me to my second question).
2. I have stream of vapour with a mass flow rate of Y and pressure P1. It's mixes directly with another stream of liquid with a mass flow rate of Z and pressure P2. Will the resulting stream have a pressure of P3=(P1+P2)/2? (Presuming they mix in a normal Open Feed Water Heater)
If anyone can give me links that might answer any of my question, or answer them personally I'll be much obliged.
Ps: (I've tried using this site: http://www.postmixing.com. But it's not working at the moment)
Open Feed Water Mixer Questions
Started by Guest_ellajid_*, Jun 02 2009 04:03 AM
No replies to this topic
#1 Guest_ellajid_*
Posted 02 June 2009 - 04:03 AM
Waste WaterStarted by Guest_refluxraider_* , 14 Apr 2024 |
Water Seal DrumStarted by Guest_Ali4269278331_* , 05 Apr 2024 |
Rapid Depressurization Of WaterStarted by Guest_golegolegole_* , 31 Mar 2024 |
Pe Chemical Practice Exam QuestionsStarted by Guest_AthlonXPme_* , 31 Mar 2024 |
Water Seal Pot Of Prv Working PrincipleStarted by Guest_panagiotis_* , 23 Feb 2024 |
