What is the difference between an ERV (Emergency relief valve) and a PSV ?
Difference Between Erv And Psv
Started by ayan_dg, Jun 08 2009 01:39 AM
Posted 08 June 2009 - 01:39 AM
Posted 08 June 2009 - 06:21 AM
Ayan:
An emergency relief valve is a term normally used for a device used on an atmospheric storage tank (API 650 type). This device is used as a means of¨"last resort" - in other words, it is intended to work by opening wide open and saving the tank in the event a catastrophic over-pressure should occur and the normal relief devices are over-whelmed. This would constitute an "emergency" and that is the name given to the device. Physically, the device usually is nothing more than a weighed, blind flange set on top of a large flanged nozzle. The blind flange can be hinged or, when the user is a cheap skate, it can simply be chained to the base flanged nozzle. These precautions are taken in order to avoid having a heavy piece of steel flying through the air during an emergency discharge.
I am not going to define a PSV because that is something you should be familiar with and you can easily research or look it up on the internet.
I hope this explanation has helped you out.
Answered
Difference Of Face Velocity In Aircooler Unit With Multiple Services.Started by Guest_AnbIran_* , 20 Mar 2023 |
Difference Between Estimated Stream And Actual StreamStarted by Guest_skyicetel1_* , 20 May 2022 |
Temperature Difference Heat ExchangerStarted by Guest_Petridou_* , 04 Mar 2021 |
Difference Between Pump And CompressorStarted by Guest_Charan_123_* , 10 Dec 2018 |
Temperature Difference In Plate-Fin ExchangeStarted by Guest_Ghasem.Bashiri_* , 03 Feb 2021 |
