A ball at a temperature of 20degrees moves through a liquid A at a temperature of 60degrees which is constant. Inside the ball is liquid B, which is also at a temperature of 20 deg.
The heat transfer resistance between the exterior surface of ball and liquid is to be neglected. Also no temperature profile exists in B. I need to find the evolution of temperature of liquid B with time.
This is what I did:
Rise in heat content of B = Heat transferred through the wall of the ball.
dQ/dt = UA(log mean temp difference)
now Q=(mCp(del T))ball
del T = T(Liquid B final) - T(liquid B initial)
Can anyone tell me what will be my log mean temperature difference here?
The temperature of the ball is changing. The temperature of the liquid B is changing. Is it right, if I am getting a coupled ODE?
Heat Exchange
Started by , Jun 08 2009 04:47 AM
No replies to this topic
Posted 08 June 2009 - 04:47 AM
Time Required To Heat Up A Fluid In A VesselStarted by Guest_panagiotis_* , 24 Jan 2023 |
Plate Fin Heat ExchangerStarted by Guest_shazzad1613_* , 23 Mar 2024 |
Heat Exchanger Temperature CrossStarted by Guest_kaidlut_* , 20 Dec 2022 |
Temperature Cross Heat ExchangerStarted by Guest_Priolo_* , 12 Aug 2019 |
Best Heat Exchanger Type For Gas HeatingStarted by Guest_golegolegole_* , 29 Jan 2024 |
