Hello sirs/madams,
In one of my classes, we are being asked to identify an equipment/industrial facility that generates waste heat and create a way to recover and utilize this waste heat. I would like to ask for suggestions on how to start the project, also where I can get useful materials to support my evaluation and calculations.
Thanks a lot.
Waste Heat Recovery Facility
Started by mmssp, Jun 22 2009 07:32 PM
Posted 22 June 2009 - 07:32 PM
Posted 23 June 2009 - 04:03 AM
There are many heat recovery equipments in Boilers ( waste heat recovery boilers) and rotary calciners. But what would you want to do exactly.If you are just looking for equipment study and related calculations then i recommend you to look for books related above topics.I am sure you will get the details as the topic very common.
Posted 23 June 2009 - 02:13 PM
QUOTE (mmssp @ Jun 22 2009, 07:32 PM) <{POST_SNAPBACK}>
Hello sirs/madams,
Thanks a lot.
Thanks a lot.
Because of the lack of more detailed information, I only can suggest to you to do a Google search under the key words: Uses of waste heat and Heat recovery .
Good luck !
Waste WaterStarted by Guest_refluxraider_* , 14 Apr 2024 |
Time Required To Heat Up A Fluid In A VesselStarted by Guest_panagiotis_* , 24 Jan 2023 |
Plate Fin Heat ExchangerStarted by Guest_shazzad1613_* , 23 Mar 2024 |
