Hi:
We have 3.0 MMSCFD natural gas. My Manager wants me to liquefy this gas using J-T plant.
Can we use 900 psia pressure in J-T plant to liquefy this gas. The inlet gas Temperature is 100 F at 60 psia. Is there anyone who can help me to design this plant. Personally I think the 900 psia is too low. Main Gas is Methane
thanx allot in advance
Methane
Started by chem101, Jul 22 2009 11:35 AM
Posted 22 July 2009 - 11:35 AM
Posted 22 July 2009 - 01:01 PM
QUOTE (chem101 @ Jul 22 2009, 06:35 PM) <{POST_SNAPBACK}>
Hi:
JT plant alone may partially do the job
Please send the complete composition
AF.King
Posted 22 July 2009 - 04:33 PM
compostions are
methane 92.12%
N2 1.82%
ethane 2.26%
propane 0.61%
i-butane .44%
co2 2.75%
methane 92.12%
N2 1.82%
ethane 2.26%
propane 0.61%
i-butane .44%
co2 2.75%
Posted 22 July 2009 - 09:33 PM
QUOTE (chem101 @ Jul 22 2009, 11:33 PM) <{POST_SNAPBACK}>
compostions are
methane 92.12%
N2 1.82%
ethane 2.26%
propane 0.61%
i-butane .44%
co2 2.75%
methane 92.12%
N2 1.82%
ethane 2.26%
propane 0.61%
i-butane .44%
co2 2.75%
Some other info:
- What is the source of this low pressure lean feed gas? is it from an up-stream NGL cryogenic plant (feed heavy up-to IC4 alone)
Is the feed gas saturated with water at 100 F and 60 psia?
-Any data about mercury content
- The feed gas shows some NGL. DO you want to recover first this NGL
- If you want to liquify the whole stream then do you want it at atmpshric pressure (at about -166 deg. C)
- Also there is apperciable amount of CO2. If you want to liquify the whole feed then:
- Inlet compression
- Up-stream conditioning (Hg and CO2 removal and Bone dry Mole sieve)
- C3 plus removal
- MCR or cascade refrig to liquify the C2 minus gas
Steam Methane Reformer In Production Of Methanol From Natural GasStarted by Guest_adam123collings_* , 01 Mar 2022 |
Steam Methane ReformerStarted by Guest_asma1411_* , 05 Nov 2021 |
Hysys User Variable For Methane NumberStarted by Guest_akhtyamov_* , 22 Dec 2020 |
Total Hydrocarbon(As Methane)Started by Guest_Ashish Chouhan_* , 20 Mar 2018 |
Upstream Nitrogen Rejection Without Loss Of MethaneStarted by Guest_mputupai_* , 25 Jan 2019 |
