Statistical Tool For Finding Correlation
8 replies to this topic
#1 conan_kaya
conan_kaya
  • 20 posts
Posted 14 August 2009 - 09:21 PM
Hi all,
Can anybody recommend me a statistical tool for finding correlation.
  • 6,340 posts
Posted 14 August 2009 - 10:11 PM
Good day ,
Let you try Excel , there is a function called "linest " which should support your query .
#3 conan_kaya
conan_kaya
  • 20 posts
Posted 15 August 2009 - 05:18 AM
can i know like how to find this "linest" function in excel?
#4 Trent F Guidry
Trent F Guidry
Posted 15 August 2009 - 09:44 AM
It really depends on what you mean by finding a correlation.
For a simple linear regression, that can be done in Excel.
Some nonlinear equations, such as the Clausius Clapeyron equation can be rearranged so that they can then be linearly regressed. While this sort of rearrangement isn’t really a true regression of the original equation, it is usually fairly close.
If you have to do a nonlinear regression, such as for the Antoine correlation for vapor pressure, then that gets much more involved. One of the more popular algorithms for doing that is the Levenberg Marquardt algorithm. The Gauss Newton algorithm can also sometimes work, but it tends to have pretty severe stability issues. Another approach is to create an equation of the residual errors and then use an optimization routine to minimize that function. I have seen that approach taken using quasi Newton algorithms such as the Davidson Fletcher Powell and the BFGS algorithm.
#5 breizh
  • 6,340 posts
Posted 15 August 2009 - 08:54 PM
On excel , let you use the wizard (?) and search for LINEST , you will find the description of the function and examples .
regards
#6 gvdlans
gvdlans
  • 619 posts
Posted 16 August 2009 - 01:24 AM
You can also used specialized software. I've used Tablecurve in the past. You can download a free 30 day trial version here: http://download.cnet...4-10308067.html
#7 wil ma
wil ma
  • 9 posts
Posted 17 August 2009 - 03:54 AM
...or you can use datafit www.oakdaleengr.com wich also has a time limited demo version
#8 conan_kaya
conan_kaya
  • 20 posts
Posted 18 August 2009 - 07:36 AM
For example, lets say i have the feed sulphur weight percent (S), the CCS 50% cut point temperature and CCS 100% cut poinnt temperature, is there any tools that i can use to try to form an equation using all these 3 variables to predist the weight percentage of sulphur in the product CCS?
#9 wil ma
wil ma
  • 9 posts
Posted 18 August 2009 - 11:02 AM
to form an equation you need a significant amount of (experimental) data.
the equation will only be valid (reliable) in the range of your data.
if there are no other parameters disturbing/influencing the %S in the product CCS then you can make a equation with one of those tools.
