This is the facility with which I am dealing :
Now im stuck at the 12 flow, the machinery after is the flash separator, the data i have on the 12 flow is this:
it was a liquid mixture composed by water hydrogen and CO2(11 flow), then it pass through a valve and reach the temperature of 25°C and 1 atm.
then it gives me this extra data:
12 flow: H2(%)=0.027 CO2(%)=0.37 H2O(%)=? Total-flow=?
13 flow: H2(%)=? C02(%)=? total flow=? T=25°C P=1 atm
then it says that in the 13 flow,which is composed only by gas, the CO2/H2=11.5
14 flow: H2O(%)=? CO2(%)=? total flow=? T=25°C P=1atm
i assumed that in the 14 flow(that is composed only by liquid phase compound)there is no H2 in the water mixture.
knowing this i must obtain the complete data of the 12,13 and 14 flows.
Since this is posted in the student forum, I'm going to assume this is a homework type problem, and I don't want to short circuit the learning process by doing your homework for you.
Can you explain what it is about flow 12 that you are stuck on?
Perhaps something basic to get you talking about the problem. Can you explain to me what Henry's law is? Even if you can't calculate the numbers, can you explain how Henry's law applies to the flash separator in question? Can you use Henry's law to determine whether or not the assumption of no H2 in 14 is a good assumption or not?
There is something that i forgot to mention(my fault)in my post that was really important to solve the problem, i have the hernry constants for both H2 and CO2(given by text), then i already know the basic equations for the flash separator and are this one:
henry law for the flash:
P
tot*Y
H2=H(H2)*X
H2 same for CO2
global balances:
z
*F=V*Y
H2+L*X
H2 this formula can be also written for CO2
Y
H2+Y
CO2=1
F=V+L
Where F is the total flow of stream 12 and V and L are,respectively, the flow of 13 and 14 streams.With this set of equation i could not solve this point of my problem since i had more unknows(F,V,L,X&Y for H2,X&Y for CO2) that equations(5 basic eqautions).
I can add another equation at my basic 5 since the CO2/H2 ratio given by text can be written as: Y(CO2)/Y(H2)=11.5 , but i still have 7 unknows vs 6 equtions, this is were i'm stuck.I'm searching for antoher equation or to find a way to obtain one of F,V or L.
At this point i omitted one another important thing, if you look at the picture there is the flow number 3 that is the exit from the primary reformer, i have every information of this flow(%compostion,total flow) but from this point until the flash i have no data, the problem jumps directly to the flash separator.
At this point my question cahnges,after the flow is passed through the secondary reformer, the two shift recators and the the column of sepration ,can i assume that all CH4 and CO from flow 3 becomes CO2 that is added to flow 12?
Finally, a small clarification, this is not a "homework" in the strict sense of the word,it is only an old exam wich i used(as the other that i have)for prepare myself to the september exam session.
