How to calculate Cv of a control valve handling two phase flow at its inlet.
Cv Value For Control Valve In Two Phase Flow
Started by ayan_dg, Sep 09 2009 05:47 AM
Posted 09 September 2009 - 05:47 AM
Posted 09 September 2009 - 09:11 AM
The Cv of a control valve is a property of the valve itself, and the fluid passing through the valve is not relevant to this definition. In other words, the valve's Cv is the same whether it's passing water, oil, vapors, or a two phase mixture.
That said, beware of using a control valve for a two phase flow system and believing you will understand its performance. If the fluid is non-homogeneous two phases entering the valve, I think it would be very difficult to know what to expect from the valve. I would consult with the valve's manufacturer for guidance.
Posted 09 September 2009 - 09:25 AM
Ayan,
Check out page 11 for CV calculation of two-phase flow of 'Masoneilan control Valve Sizing Handbook'. Available as a free download from the net.
Can Anyone Provide Me The Reference Datasheet For Deluge Valve?Started by Guest_Radha Krishnan Siva Kumar_* , 16 Apr 2024 |
Flow Switch High RangeStarted by Guest_Lyne_* , 11 Apr 2024 |
Hydrocarbon Dew Point Control UnitStarted by Guest_BabRafiq1_* , 05 Apr 2024 |
Valve Cv InputsStarted by Guest_QuantumEng_* , 01 Apr 2024 |
Kettle Reboiler Flow FractionsStarted by Guest_Lyne_* , 31 Mar 2024 |
