I'm a final year student doing my design project on Catalytic Reforming. I am currently designing a distillation column for the separation of C5+ reformate and LPG. In order to do this, I have been using Aspen HYSYS for liquid and vapour values, and Chemical Engineering Design by RK Sinnott, for design method. I have specified n-pentane as my Heavy Key and n-Butane as my Light key, and the column has 8 stages.
The problem I have encountered is that my feed contains a greater quantity of liquid and not much vapour, this causes the liquid-vapour flow factor, FLV, to be quite high (around 8.6). I am supposed to use FLV to work out a K1 constant (K1 is used to work out vapour flooding velocity) from figure 11.27 in Sinnott (pg. 568), however the graph in figure 11.27 has a maximum value for FLV of 5.0, hence I cannot obtain the necessary K1 value from the graph. I tried extrapolating the values however this is not valid since the graph is constructed from experimental data.
Is there any other way I could design this column? or are the sources where I can find the K1 constants with greater FLV values?
I'm attaching my design rationale spreadsheet and my catalytic reforming unit HYSYS simulation in .XML file extension.
Thank you for your time.
MS
