Dear Sir,
In my hysys simulation , for suction scrubber,fuel gas KOD there is no flow at liquid condensate ie full of vapor.But for the vessel designing how we consider the liquid condensate flow rate.Please specify any basis for considering liquid condensate flow for vessel designing purpose.
Please help me.
thanking you.
regards,
Kasri
Condensate Flow Rate In Kod Design
Started by kasri, Dec 10 2009 11:33 PM
Posted 10 December 2009 - 11:33 PM
Posted 11 December 2009 - 09:01 AM
It depends on your system, as usual.
You should try to envisage which kind of liquid you may encounter: perhaps water, for example during startup, or condensed hydrocarbons if your gas is off-spec, temperatures are low, or if you get carry-over from some upstream unit operation. Take the most conservative (lowest) density of all credible scenarios for sizing. Flow rate is not really important, you should allow sufficient space in the bottom part to put all the required instrumentation in.
Design And Fabrication Of Reflux DrumStarted by Guest_Femi_* , Yesterday, 03:05 PM |
Jt Based Hcdp Design V/s Mechanical Refrigeration Hcdp Unit.Started by Guest_BabRafiq1_* , 19 Apr 2024 |
Rupture Disc DesignStarted by Guest_chaupradip_* , 13 Apr 2024 |
Flow Switch High RangeStarted by Guest_Lyne_* , 11 Apr 2024 |
Falling Film Reactor Design CalculationStarted by Guest_Emranm02_* , 07 Apr 2024 |
