Hi, i have some problem with simulink. in simulink we can solve this equation : d^3y/(dx)^3+6d^2y/(dx)^2+11dy/dx+6y=1, both using integrator block or laplacing it first and using transfer function block... the problem is my lecturer want me to solve another equation d^3y/(dx)^3+6d^2y/(dx)^2+11dy/dx+6y+y^2=1. he want me to solve it using both ways.. i stuck with y^2.. i don't know how to transform it to s-domain nor using integrator block directly without laplacing it.
can anyone help me? thanks before
Simulink Problem
Started by leon_aurel, Mar 18 2010 02:00 AM
Posted 18 March 2010 - 02:00 AM
Posted 18 March 2010 - 07:56 AM
I've attached a pdf which will allow you to solve the problem. There's one thing I don't like about your problem... it's a tiny little thing you'll need to remember: Laplace and simulink work from the time plane to the s-plane. Said that, your equation is miss-typed unless your time axis is the "x-axis".
I hope it'll help you out.
Your transform block should be taken from:
s^3*y(s)-s^2*y(0)-s*y'(0)-y''(0)+6[s^2*y(s)-s*y(0)-y'(0)]+11[s*y(s)-y(0)]+6*y(s)+2/y(s)^3=0
Posted 18 March 2010 - 11:36 AM
oh..i'm sorry..my fault..i forget about the x-domain. thanks for the literature..
Posted 18 March 2010 - 12:51 PM
Sorry Andres, but i still can't understand why y^2 can be transformed to 2/y(s)^3...
Problem With Writing Offshore Plant Design BasisStarted by Guest_Doneisbetterthenperfect_* , 01 Dec 2023 |
Problem With Writing Offshore Plant Design PfdStarted by Guest_Doneisbetterthenperfect_* , 06 Dec 2023 |
Crude Oil Stripping (H2S Conc. Specified In Gas Phase Problem)Started by Guest_nabeelsp1036_* , 16 Jun 2023 |
Aspen Hysys Rankine Cycle ProblemStarted by Guest_ELLEPI_* , 17 Apr 2023 |
Low Velocity Problem Of Fluid In Hairpin Heat ExchangersStarted by Guest_AnbIran_* , 16 Jan 2023 |
