Posted 08 September 2010 - 11:47 PM
Section 3.5 "Displacement pump flow control" in Pump Handbook by Karassik, 3rd edition explains in series operation of displacement pump and centrifugal pump.
Extract from the book is below:
FLOW CONTROL IN COMBINED DISPLACEMENT AND CENTRIFUGAL PUMPS
Systems that involve both centrifugal and reciprocating positive displacement pumps deserve some special consideration. Centrifugal pumps are often used as suction boosters to overcome acceleration head requirements peculiar to reciprocating pumps but are rarely used to supplement flow. Some unique characteristics of each type of pump that affect the other type must be considered in the design, operation, and control or the interrelated system.
Series Operation, Suction Boost
The flow rate is always determined by the positive displacement pump capacity and is independent of the centrifugal booster pump. The capacity is therefore controlled as with any positive displacement pump.
The purpose of the centrifugal pump is to supply sufficient pressure to satisfy the suction requirements of the positive displacement pump. The centrifugal pump must be sized to provide the maximum rate of flow of the positive displacement pump at a pressure high enough to meet the NPSH requirement of the latter. With a flow-controlled positive displacement pump, speed control of the booster might be considered, as illustrated in Figure 4. The system pressure requirement can be satisfied by the positive displacement pump at all flow rates; therefore, total energy requirements may be reduced by using the less efficient centrifugal pump to develop no more than the required suction head. If the centrifugal booster pump is run at constant speed, its share of the total head requirement will increase as system capacity is reduced.
Sachin
