Edited by omechem, 16 October 2012 - 06:49 AM.
How To Learn Htri Xchanger Suit 6,if Anybody Having Learning Manual Pl
Started by omechem, Oct 16 2012 06:47 AM
Posted 16 October 2012 - 06:47 AM
how to learn HTRI Xchanger suit 6,if anybody have learning manual please send me my mail id was ome06028@gmail.com
Posted 16 October 2012 - 10:17 AM
Hello Omechem,
The software itself has a very extensive and useful manual. If you have the software installed, I'm sure you will have access to it. However, I think that learning any software requires time and some "contact" with it. In the case of an engineering software, you will use your technical knowledge and your common sense to determine if your results are, at least, logical.
Always remember that the software is a calculation tool, it won't do all the work; and also remember that the quality of the results will depend on the quality of your input (garbage in - garbage out).
If there's any book or website, I'm sure that one of our colleagues here will share it with you. My advice, read the HTRI user manual, take a couple of exercises (trying to design an existing unit and compare your results for example), and you will learn to use it quickly (that's how I've learned to use it).
Posted 16 October 2012 - 10:01 PM
omechem,
if you haven't a tutor, I'd suggest you to participate to HTRI training sessions and webinars (and also to follow Fr3dd advices).
Recommendation For Self-Learning Chemical Engineering.Started by Guest_Dumpmeadrenaline_* , 25 Mar 2023 |
Manual Creating New Component And Setting Properties In HysysStarted by Guest_Platonicus_* , 15 Mar 2023 |
Htri SimulationStarted by Guest_Santoso13_* , 12 Mar 2023 |
Pct Tube Removed Result In HtriStarted by Guest_cincao_* , 29 Oct 2022 |
Courses & Learning PlatformsStarted by Guest_R_Gowtham_* , 11 Jul 2022 |
