in the progress of designing a hydrogenation process I am modeling a few things using Aspen Plus.
At the moment a flash is giving me headaches. Its basically a vapour-liquid flash of tert-butanol, Hydrogen and some Ammonia. I am working at pressures of 150bar, 150°C and struggeling with chosing a property method.
I already did some reading in guides on chosing property mehtods, but still am not sure which ones to use. When using EOS's, lots of tert-BuOH goes out with the vapour phase.
With activity coefficient prop. methods, the system behaves as I would expect - most of H2 as vapour, most of tert-BuOH as liquid - but it's recommended NOT to use activity coefficient methods at high pressures - so I am kind of confused.
- maybe i just got a wrong understanding of the system, and there is some good physical explanation why this much of tert-BuOH leaves my flash as a vapour...
I would appreciate any advice!
thanks so much
Advice In Property Method Selection Aspen Plus
Started by lindaar, Nov 16 2012 03:31 AM
property method aspen plus
Posted 16 November 2012 - 03:31 AM
Posted 16 November 2012 - 09:10 AM
Ultimately when selecting a thermo model, you want the one that best mimics reality. I would suggest at this point that you find some VLE data in the literature for H2 systems and see which of your models seems best. I know there are data out there for H2 + hydrocarbon systems; I'm not sure how extensive the data for H2 + alcohol systems are.
Advice For A Future EngineerStarted by Guest_Turtletoo_* , 01 Jun 2026 |
Sulfuric Acid Plant Aspen Hysys HelpStarted by Guest_kazuki222_* , 29 Apr 2026 |
Aspen Plus Conceptual Mof Synthesis Model: Elecnrtl, Ionic Leachate, PStarted by Guest_Momo_212_* , 16 Apr 2026 |
Energy Analysis In Aspen Plus 14.2Started by Guest_Sarishma_* , 23 Mar 2026 |
