Hi everyone,
i'm doing a project about fired heaters, checking how big are the gains in efficiency when the convection section gets a chemical cleaning.
The system is a cylindrical heater with vertical coil, has convection section with studded tubes and has dual fuel burners (fuel gas and fuel oil). I was checking the background data about the flue gases temperature at the stack and at the bridgewall and i found that when the cleaning occurs both temperatures drop. And that drop is more significant in the bridgewall that in the stack.
I thought that the bridgewall temperature after the cleaning would remaing the same. what is the reason for the bridgewall drop?
