I have a relief valve on an 98% Sulfuric acid storage tank. When it is heated by fire the H2SO4 will boil and give off a vapor? What is this vapor?
Is it H20 and SO3 or is it just H2SO4 vapor?
How do I determine the density of the H2SO4 vapor?
Posted 21 November 2013 - 05:52 PM
Posted 21 November 2013 - 07:20 PM
The sulfuric-acid water azeotrope is at 98.4 wt%. Typically H2SO4 above 98% is fortified with SO3, that can attack even PVDF. The boiling point is around 330 deg C. If it isn't fortified, you can just read the H2SO4/water concentration off a VLE diagram such as that in link below. Typically a desiccant dryer is fitted in vent, so there won't be a relief valve. I would expect the vent sizing to be based upon maximum fill rate rather than fire sizing. See http://www.generalch...nical-data.html for most physical properties including VLE. At 98% in liquid phase, you'll have about 80% H2SO4 in vapor phase, this assumes no SO3 or oleum fortification and atmospheric pressure. Density may be calculated based upon vapor density of the pure components.
Wafer Check ValveStarted by Guest_Ali4269278331_* , Yesterday, 01:31 PM |
Flash Steam Vessel SizingStarted by Guest_JohnFields343_* , Yesterday, 12:03 PM |
Can Anyone Provide Me The Reference Datasheet For Deluge Valve?Started by Guest_Radha Krishnan Siva Kumar_* , 16 Apr 2024 |
Sulphuric Acid H2So4 Storage TankStarted by Guest_TeeEng_* , 08 Apr 2024 |
Valve Cv InputsStarted by Guest_QuantumEng_* , 01 Apr 2024 |
