Hi everyone
For dynamic simulation, I need some guidance for determining liquid flowrate passing through an XV (HIPPS shutdown valve) while XV is closing. XV is 20" ball valve. A consultant will perform the dynamic simulation. Any guidance will be appreciated. For on-off valves, Is there any information on characteristic curve. Please let me know if its clear.
Fez
Valve Characteristic Curve For On-Off Valve
Started by seeker_of_knowledge, Dec 14 2013 08:37 PM
Posted 14 December 2013 - 08:37 PM
Posted 15 December 2013 - 04:25 PM
Fez, Cv vs %open data are readily available from numerous ball valve manufacturers. The typical curve is, of course, non-linear. You will also need data on how quickly the actuator closes. For instance, see http://www.kthsales....fischer/343.pdf
Posted 13 January 2014 - 07:39 PM
Thanks Fsiepel.
