I am currently checking the Capacity of Vacuum relief valve of our ammonia storage facility and I came across a phenomena called Barometric inversion.
I would like to know about it. What it means? Why it is considered in the design basis?
Posted 19 December 2013 - 11:11 PM
Posted 20 December 2013 - 03:17 AM
It appears to be related to atmospheric pressure change due to temperature inversion. If so, the density of the sucking air due to a vacuum inside the tank will be changed and the capacity of the relevant vacuum relief valve as well.
Wafer Check ValveStarted by Guest_Ali4269278331_* , Yesterday, 01:31 PM |
Design And Fabrication Of Reflux DrumStarted by Guest_Femi_* , 22 Apr 2024 |
Jt Based Hcdp Design V/s Mechanical Refrigeration Hcdp Unit.Started by Guest_BabRafiq1_* , 19 Apr 2024 |
Can Anyone Provide Me The Reference Datasheet For Deluge Valve?Started by Guest_Radha Krishnan Siva Kumar_* , 16 Apr 2024 |
Rupture Disc DesignStarted by Guest_chaupradip_* , 13 Apr 2024 |
