Amount Of Steam Needed
#1 Akshay Jeebodhun
Akshay Jeebodhun
  • 15 posts
Posted 05 March 2014 - 02:16 PM
Hello all,
I hope you are fine.
I have been given to design a deaerator.  I have to calculate the amount of steam needed to increase the  temperature to 105 deg C in the pressurized deaerator operating at a pressure of 1.2 bar.
Condensate return water
Temperature = 98 deg C
Assumption: The amount of steam generated to be used in dyeing machines( TEXTILE INDUSTRY) is equal to the amount of condensate return.
Therefore, Mass flowrate of return condensate = 22,000 kg/hr
Makeup water
The water entering the deaerator is at 85 deg C.
Mass flowrate = ??
Boiler feedwater
Temperature = 105 deg C
Mass flowrate = 22,372.9 kg/hr
Boiler is operating at a pressure of 5 bar and producing saturated steam at a flowrate of 22,000 kg/hr
Flash Steam
Mass flowrate = 34.6 kg/hr
Edited by Akshay Jeebodhun, 08 March 2014 - 06:33 AM.
#2 Said Salim
Said Salim
  • 98 posts
Posted 05 March 2014 - 11:35 PM
Hi Akshay.
Can you please illustrate your problem by a sketch.
#3 Akshay Jeebodhun
Akshay Jeebodhun
  • 15 posts
Posted 05 March 2014 - 11:48 PM
Hi Akshay.
Yes sir. i've edited my post
i've attached the sketch
thnks ;)
#4 breizh
  • 6,722 posts
Posted 06 March 2014 - 12:48 AM
AKSHAY,
Let you perform heat and mass balances around your system and probably chemical analysis( like TH or others)  on some or all water streams to get the full picture .
first of all start with a simplified PFD and identify all the streams , recirculation ,inlet ,outlet ,data available ....
at the end you need to perform the reconciliation of all the data , a tool like solver can be helpful.
Hope this helps
#5 Akshay Jeebodhun
Akshay Jeebodhun
  • 15 posts
Posted 06 March 2014 - 07:09 AM
AKSHAY,
Hope this helps
Mr Breizh
i am provided with only the steam consumption which is 22 ton/ hr ( saturated steam @ 5 bar)
Furthermore, i also know the condensate return which is 22 ton/hr(close circuit) @ 98 deg C.
I've done a mass and energy balance on deaerator as follows : -
Mass balance :     S + MW + C + FS = FW
                            S + MW + 22,000 + 34.6  = 22,372.9             ----------eq 1
Energy Balance : S.(h1) + MW(h2) + C(h3) + FS(h4) = FW(h5)
Where h1 = enthalpy of saturated steam @ 5 bar = 2749 kJ/kg
          h2 = enthalpy of  Make-up water @ 85 deg C = 355.9
          h3 = enthalpy of condensate @ 98 deg C = 409 kJ/kg
         h4 = enthalpy of Flash steam @ 1.2 bar = 2680.4 KJ/kg
Edited by Akshay Jeebodhun, 08 March 2014 - 06:38 AM.
#6 breizh
  • 6,722 posts
Posted 06 March 2014 - 07:05 PM
Seems OK ,
Just don't forget to mention the reference for enthalpy ( 0C and liquid state) I guess and for water you need also to add the pressure for your stream  ( 105 C , 1.4 bar as an example).
Hope this helps you out.
#7 xavio
xavio
  • 102 posts
Posted 07 March 2014 - 12:44 AM
Akhsay,
In reality, there is heat loss to environment from your deaerator vessel.
As breizh pointed out, you should consider P, T in your enthalpy --> h(P,T), because some streams are not in saturated state.
Overall you should get close enough result.
Good luck.
xavio
