Dear All
Greetings !!
I am working on Hydraulics of a long Pipeline . I assumed the Diameter and calculate the pressure drop . I Have following doubts though which I need kind explanation .
1. My total pressure drop through Pipeline is 78 (98 to 20 ) Bar . This pipelines has spur lines Taking -Off the natural Gas intermediately, in turn changing the hydraulics . When i do calculations section-wise there are some sections where pressure-drop is less than 40% of the inlet pressure of that section .
- I refereed to Crane Tech paper -410 . And it states that For Pressure drop more than 40% , calculation should be made by Isothermal equations (Panhandle-
in my case .
- In Crane there is a Height correction factor mentioned. some time when the pipeline is descending it give negative (-) Pressure drop that means increasing pressure , Is it practically possible in case of Natural gas (pressure around 45-50 barg) .
- There is a Height correction factor in " Handbook of Natural Gas Transmission and Processing" by Saeid Mukhatab which is not in agreement with The Height correction factor mention in Crane , Latter one seems to be more correct and reliable though.
I seek guidance whether I need to use in-compressible flow equation for the section where pressure drop is less than 40% than the inlet pressure .
2. Is their some clear-cut criteria to use these equations , Pan-A, Pan -B , AGA and others . How do we judge and justify using one over other
3. I am not getting any material regarding Pipe Efficiency factor and its value .
Your kind help is appreciated
Sahil
