Api 521 Section 4.2.1 Hierarchy Of Protective Measures
api 521 overpressure
8 replies to this topic
#1 Sherif Morsi
Sherif Morsi
  • 173 posts
Posted 30 April 2014 - 07:07 AM
In API 521 6th "section 4.2.1 Hierarchy of Protective Measures (page 12)", a hierachy should be used to avoid overpressure of equipment:
1- Avoid (reduce) risks: set MAWP of the vessel above the max pressure of all possible sources
2- Provide engineering controls: pressure relief on the vessel
3- Provide administrative controls: include provision of block valves of the locked-open design.
What does "locked-open design" mean?
Thanks,
Sherif
#2 fallah
  • 5,019 posts
Posted 30 April 2014 - 07:21 AM
Sherif,
"Locked-open design" means the inline valve to be locked in open position such that could be considered as a part of the line with no possibility of blocking...
#3 Sherif Morsi
Sherif Morsi
  • 173 posts
Posted 30 April 2014 - 07:42 AM
Thanks Fallah. Appreciate your help
Sherif
#4 Manan_Joshi
Manan_Joshi
  • 7 posts
Posted 30 April 2014 - 09:31 AM
I believe my understanding is correct.  It means the isolation valve or the downstream control valve of the equipment to be CAS or fail open as applicable.  Is this correct ?
#5 Bobby Strain
Posted 30 April 2014 - 03:38 PM
But I would never use such for overpressure protection.
#6 Sherif Morsi
Sherif Morsi
  • 173 posts
Posted 05 May 2014 - 12:10 PM
Bobby,
I wouldn't use it as well for overpressure protection, however block valves upstream and downstream relief valves are installed for maintenance purposes in case of redundant PSVs. Do you have specific reasons that would add to my knowledge?
Appreciate your input
Sherif
#7 fallah
  • 5,019 posts
Posted 05 May 2014 - 01:06 PM
Sherif,
Yes, these isolation valves have to be used for maintenance and change over of the redundant PSV but those of the working PSV should be locked-open for safety issue and to avoid overpressure due to inadvertent closing.
Therefore these locked-open valves aren't basically used as overpressure protection facility, but when have to be used then have to be in locked-open position...
#8 Manan_Joshi
Manan_Joshi
  • 7 posts
Posted 23 May 2014 - 12:08 PM
Sherif is correct and the isolation valve are CSO and CSC type.  I want to ask does anyone will extend this to control valve bypass ? especially when the scenario becomes governing.
#9 Sherif Morsi
Sherif Morsi
  • 173 posts
Posted 23 May 2014 - 12:21 PM
For control valves, it is subject to the application and the pressure rating of the system. Sometimes, bypass isolation is Normally Closed "NC" and sometimes Locked Closed "LC" (CSC). From my limited experience, with high pressure systems and especially with gases, they are LC.
