Teg Hysys Simulation Problem
Posted 15 April 2015 - 06:25 AM
Posted 15 April 2015 - 10:06 AM
The number of stages does not affect the removal of H2O much at all. The main variables to observe are: TEG circulation, TEG purity, Temperature, Pressure. I would trust GPSA more than HYSYS for TEG dehydration. HYSYS isn't ordinarily used for dehydration applications. I wouldn't expect very accurate results. I don't think you will need more than about 4-6 trays for this. 2.5 gal TEG/lb of H2O is reasonable.
I can't help you with your HYSYS model because I don't use that simulator any more.
Posted 15 April 2015 - 12:45 PM
Mosayef,
could you kindly give the gas composition?
Maybe someone without Hy$y$ could give you some advice.
Posted 22 May 2015 - 10:32 AM
In addition to above items, You could also changed the regeneration tempreature of TEG reboiler in less temperature as spec of your column. (Generally due to degradation is set on 204c) for example decrease it to 190c. It could be changed your water content to higher value in dehydrated acid gas, also change on concentration of TEG in less concentraion is another method for higher water content .
Obviously, This changes should be ecconomically investigated and best scheme should selected.
Posted 22 May 2015 - 02:09 PM
![]() Syngas Plant SimulationStarted by Guest_kaidlut_* , 28 Jun 2025 |
![]() Teg Regeneration Hysys HelpStarted by Guest_connex_* , 17 Jul 2025 |
