Is it necessary to control the pH of raw wastewater in sump tank? Does this idea work?
Description:
-install a pH sensor in sump tank
-implement acid and caustic dosing in sump tank to control the pH to certain range (i also not the range).
Wastewater Treatment Plant Design
Started by , May 25 2006 08:46 PM
Posted 25 May 2006 - 08:46 PM
Posted 22 September 2006 - 08:48 PM
QUOTE (julia lim @ May 26 2006, 09:46 AM) <{POST_SNAPBACK}>
Description:
Description:
[font=Verdana][size=7]
Dear Ms Julia:
1) pH sensor is preferably installed in the reaction tank. If your influent is too acidic or too basic you can have the adjustments done in the reaction tank followed by coagulant application. The next step is the application of floccullant. The supernatant liquid is then cleaned further from the accompanying dissolved solids and neutralized to the standard pH range. Installing a pH sensor in the sump tank is for me not a wise idea.
mackie cantal
Rupture Disc DesignStarted by Guest_chaupradip_* , 13 Apr 2024 |
Falling Film Reactor Design CalculationStarted by Guest_Emranm02_* , 07 Apr 2024 |
Sulfuric Acid PlantStarted by Guest_Kartik54_* , 16 Mar 2024 |
Design Gauge Pressure Inlet To A Centrifugal Compressor.Started by Guest_Mohammad3799_* , 03 Mar 2024 |
