https://drive.google....ew?ts=56e78018
First link die, please find the second link in below
https://issuu.com/su....n_6_strands_an
This publication is based on the research & practical experience cases (Mr.Pieter Kampers) and follow up IMCA guideline & EN 12385-4 Standard. Cable Laid/Cable Laid Gromment Slings is made from Unit rope/wire rope. After researching and through out some practical experience cases, we found out that: if Cable laid/cable laid Grommet slings made by unit rope/wire rope with 8 strands & EEEIPS grade, it will be brittle at the bend of cable laid/cable laid grommet and make it be cracked/damaged (as picture) because the 8 strands ropes have a larger core and they are more sensitive to core issues, the core rope of and 8-strand rope has, compared to the outer strands, a very big diameter. Therefore, we advise to use Cable laid/cable laid Grommet slings made by unit rope/wire rope with 6 strands & EEIPS grade will be good for lifting slings as IMCA & EN 12385-4 instruction.
The Difference Between 6 Strands And 8 Strands Using For Cable Laid
Started by steve_lee05, Mar 22 2016 02:16 AM
No replies to this topic
Posted 22 March 2016 - 02:16 AM
Answered
Difference Of Face Velocity In Aircooler Unit With Multiple Services.Started by Guest_AnbIran_* , 20 Mar 2023 |
Difference Between Estimated Stream And Actual StreamStarted by Guest_skyicetel1_* , 20 May 2022 |
Temperature Difference Heat ExchangerStarted by Guest_Petridou_* , 04 Mar 2021 |
Difference Between Pump And CompressorStarted by Guest_Charan_123_* , 10 Dec 2018 |
Temperature Difference In Plate-Fin ExchangeStarted by Guest_Ghasem.Bashiri_* , 03 Feb 2021 |
