In one of our CDU’s recently we had a leak on the joint between the ¾” overhead neutralizer injection line and 24” overhead vapor line of atmos column. Internal corrosion was observed on the leak area. The pipes thickness was measured at different parts around the leak area and found to be OK. It indicates localized corrosion. We are using neutralizing amine as neutralizer. We are unable to find the root cause of the failure. Are there any instances like this in other refineries? If so, what might be the probable reasons?
Corrosion In Overhead Neutralizer Injection Line Of Crude Distillation
Started by kaushik avs, Apr 19 2016 04:33 AM
corrosion crude distillation column neutralizer
Reactive Distillation MtbeStarted by Guest_Michael Mitra_* , 15 Mar 2024 |
Vacuum DistillationStarted by Guest_hysyshunter_* , 12 Mar 2024 |
Distillation Column DiameterStarted by Guest_refluxraider_* , 12 Mar 2024 |
DistillationStarted by Guest_refluxraider_* , 13 Mar 2024 |
Diameters Of A Structured Packing Distillation Column With No VapourStarted by Guest_hysyshunter_* , 07 Mar 2024 |
