I want to use the Levenspiel Plot to size chlorine disinfection tanks for CSTR and PFR, but I don't really understand what I'm doing and my lecturer was no help. I'm an enviro eng student so some of this chemistry stuff is a bit confusing as we only do bits and peices of it. I haven't been able to find a worked through example that applies to water disinfection.
Here is the process I want to apply:
http://ocw.mit.edu/c..._03072007_w.pdf
But I'm not sure what -rA is?
Is it just the reaction rate? I've assumed a k value of 2 per hour. Is this the same thing as rA?
And is XA the ratio of chlorine that has reacted to the initial chlorine?
How does XA and -rA relate to CT and k? If someone could explain those first 2 equations in the link relating to disinfection that would be super awesome.
Is there a way to actually calculate k without experimental data? I couldn't find any raw experimental data for residual chlorine decay that I could use to calculate k. I've just used 2 per hour because a couple of text book questions assumed that value, I would like something that has a bit more justification behind it but I can't seem to find anything.
Also we were given a CT value for 3log removal of Giardia and a target free residual chlorine value. So using this I was able to calculate dosages of chlorine and basic tanks volumes for PFR and CSTR.
But then we were also given a graph of Residual Chlorine against chlorine dosage. When I find the dosage required for the free chlorine target on the graph, the dosage derived from the CT and free residual target does not even get close to passing the breakpoint on the graph.
What is going on there? Does that mean that the 3log removal of Giardia occurs before the breakpoint, from the combined residual Chlorine? That doesn't seem right.
Thanks!
