Manual Override Of Antisurge Control System Of Compressor
Posted 07 September 2016 - 08:25 AM
Posted 07 September 2016 - 10:31 AM
This clarification on the requirement of manual override for ASC, at first, should be performed by who has designed/prepared the P&ID and control philosophy of the mentioned compressor...then try asking them to clarify...
Edited by fallah, 07 September 2016 - 10:31 AM.
Posted 07 September 2016 - 12:19 PM
The manuel override is required during the start up preparation of the expander and is part of the start up procedure required by the manufacturer in order to be sure that the surge valve is fully open and then the controller should be put back on auto mode before start up.
Posted 07 September 2016 - 02:28 PM
Never have I heard of such.
Posted 07 September 2016 - 02:37 PM
Anjal,
Posted 08 September 2016 - 08:37 AM
Thanks Ankur.
Thanks all for our responses.
This was a requirement from FEED Datasheet, hence thought to retain it b4 understanding is clear.
MFR doesnot know what it is
Well Ankur.
Is that has to do anything with the Calibration of Antisurge valve and its associated instruments.
Like we take the ASV Control alve in manual mode and once Calibrated then to Auto Mode.
If it is ok to discuss..
Thanks,
Closed Drain SystemStarted by Guest_Falah_* , 26 Mar 2024 |
Co2 Removal Membranes Between Compressor StagesStarted by Guest_Sinclc_* , 26 Mar 2024 |
Answered
Centrifugal Compressor Performance Curves In Aspen HysesStarted by Guest_Rafcio_* , 14 Mar 2024 |
Answered
Vacuum Ejector Pressure ControlStarted by Guest_himanshu.ch_* , 19 Mar 2024 |
Lube Oil System For TurbomachineryStarted by Guest_bckesim_* , 03 Mar 2024 |
