I am currently working on TEG Contactor to identify cause of TEG carry over and its contamination in to the downstream system. Downstream system is contaminated with TEG even though KO Drum and Filter separator installed in between TEG Contactor and downstream system. [TEG Contactor à KO Drum à Filter Separator à Downstream system]
Generally, mist eliminator in the TEG contactor is the primary cause of liquid carry over. On other hand KO Drum and Filter separator are already in place to capture those carry, but still downstream system experiencing contamination.
Any other phenomenon such as vaporization/evaporation, etc may cause potential contamination into the downstream system. Share your expertise
[Lean TEG temp. :40 degC & Wet Natural Gas temp.: 35 degC]
Thank you in advance!!
